The AirGradient Builds Overview
We are continuously updating our open hardware / open source air quality monitor kits and, as a result, have different versions of the build instructions. The version you have is written on the PCBs. Please check the table below and then click the link to the build instructions that apply to your kit.
Additionally, you can download all source files for the monitors on this page. All builds are licensed under CC BY-SA 4.0. Please ensure proper attribution.
If you have questions or run into a problem during assembly, the best and fastest way to get help is via our forum.
Firmware Repositories
The firmware for the DIY PRO / ONE and Open Air models is combined and is available on the AirGradient Arduino GitHub. Please open issues there for bugs or feature requests.
The firmware for the Open Air Max model is also available in our openair-max repository. Please open issues there for bugs or feature requests.
AirGradient ONE Indoor Monitor
Version Image of PCB / Files Main Improvements / Changes Link to Instructions Arduino Sketch Name
I-9PSL Model v9 assembled small mm4hrede 87x7d5zb
black or blue PCB
KiCad files main PCB
Gerber file main PCB
KiCad files LED bar
Gerber files LED bar
SGP41 Module
SHT40 Module
Enclosure STL
Clip-On Stand STL
Complete new design. ESP32-C3-Mini, RGB LED bar, hardware watchdog Build instructions OneOpenAir.ino
AirGradient Open Air Outdoor Monitor
Version Image of PCB / Files Link to Instructions Arduino Sketch Name
O-1PST Model oa board front 90 mm4hrejp z8nj08mv
KiCad files
SGP41 Module
CO2 Module
STL Files
AirGradient Open Air Max Professional Outdoor Monitor
Version Image of PCB / Files Link to Instructions Firmware Code
O-M-1PPST-CE-S Model max pcb mm4hrer7 almrvg2c
KiCad file main board
KiCad file cellular card
SGP41 Module
SHT40 Module
CO2 Module
STL Files
N/A. Only available fully assembled openair-max repository
Old Designs (No Longer Maintained)
DIY Basic 4.0 basic v4 mm4hrezj mmx94bl2
Gerber files
STL Files
Switched to shorter cross-over cable for PM. Made T/RH sensor slot compatible with AG module Standard version BASIC.ino
4.2 pro v4
black or green PCB
Gerber files
KiCad files
Enclosure STL
Clip-On Stand STL
Improved tracing / ground plane, removed D1 shield, changed button connection, switched to cross-over cable for PMS Standard version / Presoldered version DiyProIndoorV4_2.ino
DIY Pro 3.7 pro v3
black or green PCB
Gerber files
Enclosure STL
Clip-On Stand STL
Push button for configuration, rounded corners Standard version / Presoldered version Compatible with DiyProIndoorV3_3.ino (no push button functionality)
DIY Pro 3.3 v33 pcb mm4hrfmf ravzrkn0
black or green PCB
Gerber files
Enclosure STL
Clip-On Stand STL
Standard version / Presoldered version DiyProIndoorV3_3.ino
