The AirGradient DIY Air Quality Sensor (Basic Version PCB Version 3.0)
Please note that these are the instruction for the DIY BASIC PCB Version 3.0 that mounts the S8 CO2 sensor differently. The version number is written on your PCB. If you have a different version please find your correct build instructions in this overview.
As part of the Open AirGradient movement, this instruction teaches you how to build a compact and powerful air quality monitor with AirGradient.
You will need to have good soldering skills. If you lack soldering skills, we also offer the DIY Pro kit as a pre-soldered version for a very easy assembly that can literally be built in 5-10 minutes. More Information about the pre-soldered kit.
If you want to build a monitor with a larger display, a better enclosure and more extensibility, check out the DIY Pro instructions.
Jeff featured our DIY Basic kit on his YouTube channel and created a very nice video on how to assemble the monitor.
Skills and Equipment required
| Skill | Explanation |
| Soldering skills | The D1 Mini microprocessor and some of the components such as the OLED display need to have the pins soldered onto them. Soldering tutorial.. |
| Soldering iron & Solder | To solder the component pins and cables. |
| Computer | A Linux, Mac, or Windows computer with the Arduino IDE installed to flash the software onto the D1 Mini. |
| USB C Data Cable | To connect the D1 Mini to the computer for flashing and later for electricity. Please make sure you have a USB C cable that not only charges but can also transfer data (for flashing). |
| Wemos D1 Mini | USD 2 - 4 |
| Wemos OLED display | USD 2 - 3 |
| SHT30 or SHT31 Temperature and Humidity Sensor Module | USD 3 - 5 |
You can also purchase the kit from our Online Store. We ship world-wide.
In case you want to make your own PCBs you can download the Gerber files from PCB the Easyeda website or order PCBs from there directly. Make sure you download v3 of the PCB drawings.
| Features | |
| With temperature in Celcius |
| With temperature in Fahrenheit |
| 2 | Once it is installed, go to File, Example, AirGradient and select the DIY_BASIC code |
Put the long female and male pins through the D1 Mini. Make sure that the female parts are on top of the D1 Mini (on the same side like the USB C plug) as shown in this picture and that the labels of the OLED pins and the D1 mini align:
D1 Mini Soldering Onto PCB
The next step is to solder the D1 Mini onto the PCB. Please make sure you solder it the correct way. The USB port needs to face outwards. You can also compare the pin labels on the PCB with the ones on the D1 Mini. You can either solder the D1 Mini directly onto the PCB or use the pin headers as a socket. If you solder it directly, please leave a small gap between the PCB and the D1 Mini to make sure the plug is accessible.
Soldering The Temperature and Humidity Module
The kit might come either with the SHT3x module or the SHT40 module. The modules have a different design, so please follow the instructions below.
Instructions for SHT3x Module
If you have the SHT3x module, you need to first solder the small pins onto the module, you can again use a breadboard to fix it in place. You only need to solder the four pins. No need to do anything with the two pins on the top of the sensor.
For easier replacement of the sensor modules, solder a 4 pin female header onto the board and then put the SHT3x module onto the pin header as per picture below.
Instructions for SHT40 Module
If you have the SHT40, you do not need to solder pins as the 90 degree pins are already soldered on it but you need to solder a 4 pin female header onto the board and then put the module on it. Please note that when you put the SHT40 module onto the pin headers it needs to face backwards as per the image below.
Solder female pin headers onto the S8 PCB. Then put the S8 onto the pin headers.
Please make sure that the pins face as can be seen on this image. If you purchase the kit from us, these pins are already soldered on.
Please note that in previous versions of this PCB, the pins were soldered in the opposite way.
You can use ZIP ties to fix the S8 into place.
After you have soldered the cable or connector to the PCB, connect the PMS5003 with the other end of the cable. Then screw the PMS5003 onto the PCB or use a double sided tape to fix it in place.
Done & Enjoy
3D Enclosure And Mount
We also have a wall mount available that clicks into the vents of above enclosure and makes it easier to mount it on the wall.
AirGradient offers a sophisticated, powerful and responsive Air Quality Monitoring Solution for Schools. You can connect these DIY monitors to the AirGradient platform, and integrate with many existing brands or use our professional AirGradient ONE monitor.
