The AirGradient DIY Air Quality Sensor (Basic Version PCB Version 4.0+)
Please note that these are the instruction for the DIY BASIC PCB Version 4.0 that now uses a smaller cross-over cable for the PM sensor. The version number is written on your PCB. If you have a different version please find your correct build instructions in this overview.
As part of AirGradient's Open Hardware movement, these instructions teaches you how to build a compact and powerful air quality monitor.
You will need to have good soldering skills. If you lack soldering skills, we also offer the AirGradient ONE as a kit that is very easy to assemble and can literally be built in 5-10 minutes. More Information here.
Please note that we had a number of unexpected behaviors from different Wemos or OLED displays (e.g. freezing after some time). Since these modules are manufactured by different companies with sometimes changing components (e.g. voltage regulators), we cannot guarantee from our side that everything will 100% work. In case stability is an important aspect for your build, we strongly recommend you build our AirGradient ONE kit.
Jeff featured our DIY Basic kit on his YouTube channel and created a very nice video on how to assemble the monitor. Please note that he uses an earlier version of the PCB so a few things are now slightly different.
Skills and Equipment required
| Skill | Explanation |
| Soldering skills | The D1 Mini microprocessor and some of the components such as the OLED display need to have the pins soldered onto them. Soldering tutorial.. |
| Soldering iron & Solder | To solder the component pins and cables. |
| Computer | A Linux, Mac, or Windows computer with the Arduino IDE installed to flash the software onto the D1 Mini. |
| USB C Data Cable | To connect the D1 Mini to the computer for flashing and later for electricity. Please make sure you have a USB C cable that not only charges but can also transfer data (for flashing). |
| Wemos D1 Mini | USD 2 - 4 |
| Wemos OLED display | USD 2 - 3 |
| 10cm cross-over 8 Pin cable for PM Sensor | < USD 1 |
| SHT3x Temperature and Humidity Sensor Module | USD 3 - 5 |
| or SHT40 Temperature and Humidity Sensor Module (AG Module) | USD 3 - 5 |
Please make sure you get the cross-over cable:
You can also purchase the kit from our Online Store. We ship world-wide.
In case you want to make your own PCBs you can download the Gerber files for the PCB from the Easyeda website or order PCBs from there directly. Make sure you download v4 of the PCB.
If you do not connect it to Wi-Fi within the 180 seconds after startup it will go into the offline mode and show the air quality parameters without sending the data.
| DIY BASIC Kit |
Please note that you need to reboot the monitor after flashing in case the display does not light up.
The above direct flashing is the easiest way to get the firmware onto the D1 Mini but if you want to make changes to the code, you can also flash the code through the Arduino software environment. The software for the AirGradient DIY sensor is open source, and thus you can make any changes you’d like.
| 2 | Once it is installed, go to File, Example, AirGradient and select the BASIC code |
Put the long female and male pins through the D1 Mini. Make sure that the female parts are on top of the D1 Mini (on the same side like the USB C plug) as shown in this picture and that the labels of the OLED pins and the D1 mini align:
D1 Mini Soldering Onto PCB
The next step is to solder the D1 Mini onto the PCB. Please make sure you solder it the correct way. The USB port needs to face outwards. You can also compare the pin labels on the PCB with the ones on the D1 Mini. You can either solder the D1 Mini directly onto the PCB or use the pin headers as a socket. If you solder it directly, please leave a small gap between the PCB and the D1 Mini to make sure the plug is accessible.
Soldering The Temperature and Humidity Module
You can use either the SHT3x module from AliExpress or the special AirGradient SHT40 module for temperature and humidity. The modules have a different design, so please follow the instructions below.
Instructions for SHT3x Module
If you have the SHT3x module, you need to first solder the small pins onto the module, you can again use a breadboard to fix it in place. You only need to solder the four pins. No need to do anything with the two pins on the top of the sensor.
For easier replacement of the sensor modules, solder a 4 pin female header onto the board and then put the SHT3x module onto the pin header as per picture below.
Instructions for AirGradient SHT40 Module
If you use the AirGradient SHT40 module, you do not need to solder pins as the 90 degree pins are already soldered on it but you need to solder a 4 pin female header onto the board and then put the module on it. Please note that when you put the SHT40 module onto the pin headers it needs to face backwards as per the image below.
Solder female pin headers onto the S8 PCB. Then put the S8 onto the pin headers.
Please make sure that the pins face as can be seen on this image. If you purchase the kit from us, these pins are already soldered on.
Please note that in previous versions of this PCB, the pins were soldered in the opposite way.
You can use ZIP ties to fix the S8 into place.
In case you cannot solder these small pins, you can also cut and splice the cable and solder it directly onto the PCB. Please note that the 3rd, 6th, 7th and 8th wire is not used and can be cut.
Please note that version 4 of this PCB now uses a smaller cross-over cable. Often the default cable that comes with the PM sensor is not cross-over. See above on how to detect what kind of cable you have.
After you have soldered the cable or connector to the PCB, connect the PMS5003 with the other end of the cable. Then screw the PMS5003 onto the PCB or use a double sided tape to fix it in place.
Done & Enjoy
3D Enclosure And Mount
It will first guide you through the account creation (or login if you already have an AirGradient account).
Then you will be able to set up your place.
A place is where you can connect several monitors to. For example your house, school or office. Each place has its own dashboard.
Once you have your account and place setup,
you will be able to connect your monitor to the WiFi and add it to your place’s dashboard by following the wizard instructions.
