The AirGradient DIY Air Quality Sensor (Pro Presoldered-Version, PCB Version < 3.7)
These build instructions cover the pre-soldered version of the AirGradient Pro monitor kit for PCB version 3.6 and lower. If you have a different version please find your correct build instructions in this overview. The version number is printed on the PCB.
Skill Description
Screwdrivers You need Philips and hex (M6) Screwdrivers to close the enclosure.
Component Approx. Price
AirGradient Pro PCB with OLED Display, connectors and pin sockets
D1 Mini v4 USB-C with pre-soldered pins
Plantower PMS5003 PM Sensor with cable
Senseair S8 CO2 Sensor with pre-soldered pins
SHT31 Temperature and Humidity Sensor Module with pre-soldered pins
USB-C Cable 90-degree head
Screws The longest screws are for the enclosure. The screws with the washer head are for the PCB and the remaining screws for the PMS sensor.
The schematics
The schematics
Assembly
The assembly of the pre-soldered parts is very simple, just make sure you mount the components in the correct direction. The labels on the components should match the labels on the PCB.
D1 Mini
Put the D1 microcontroller onto the pin sockets labelled "Microcontroller". Make sure that the orientation is correct and all pins slide into the sockets.
D1 Mini Placement
D1 Mini Placement
SHT31 Module (Temperature and Humidity)
Put the SHT31 Module onto the pin sockets labelled "SHT". Make sure that the orientation is correct and all pins slide into the sockets.
SHT31 Module
SHT31 Module
SHT Module
SHT Module
PMS5003 (PMS Sensor)
The PMS Sensor is connected with the enclosed cable to the PCBs JST connector.
PMS Location
PMS Location
PMS JST Connector
PMS JST Connector
The pre-soldered version of the kit comes with the microcontroller D1 already flashed so that you can immediately use it. However, you might want to flash it again or change the code (e.g. to connect it to a different server). Also, the pre-soldered kit comes flashed by default with Celcius for the temperature unit and if you would like to use Fahrenheit you would need to reflash with below.
Note that you cannot flash through the USB-C port on the PCB as this one is only for power. For flashing always use the USB port on the D1 Mini itself.
For Standard PRO Presoldered Kit
With temperature in Celcius and Display top-left Your browser doesn't support this. Please use Chrome or Edge on Mac or PC. You are not allowed to use this on HTTP!
With temperature in Fahrenheit and Display top-left Your browser doesn't support this. Please use Chrome or Edge on Mac or PC. You are not allowed to use this on HTTP!
With Code for Optional SGP4x AirGradient TVOC Module
Manual Flashing with the Arduino Software
Step Description
2 Once it is installed, go to File, Example, AirGradient and select the PM OLED code
The AirGradient DIY sensor's hardware and software is open source and licensed under the MIT license. So feel free to use it any way you like. We would be happy to hear from you and also appreciate any link back to our page.
