The AirGradient DIY Air Quality Sensor (Pro Version PCB Version 3.7)
Please note that these are the instruction for the DIY PRO PCB Version 3.7 that has an improved PCB. If you have a different version please find your correct build instructions in this overview. The version is printed on the PCB.
  • Highly extendable e.g. with a TVOC or barometric pressure sensor, a battery charger, RGB LEDs, etc.
  • More accurate measurement for temperature as the enclosure has been designed for enhanced airflow and the temperature sensor is separated from the other components.
  • Larger OLED display allowing more information to be displayed.
You can completely build the monitor on your own with the instructions below and open-source code or, optionally you can go to our online shop and purchase it as a kit that includes a professional enclosure. We also offer the kit as a pre-soldered version for a very easy assembly.
Skill Description
Soldering skills Most of the components we use need soldering. The USB and PMS connectors are small and therefore difficult to solder but these connectors are optional and the monitor can also be built without them.
Soldering Iron & Solder To solder the component pins and cables.
Breadboard A breadboard is helpful to fix the components in place during soldering.
USB-C Data Cable A USB-C cable for flashing the microcontroller and later powering it. If you use the enclosure, you need a 90 degree USB-C cable plug.
Component Approx. Price
Wemos D1 Mini v4 USB-C USD 4 - 6
1.3" OLED display USD 3 - 5
Plantower PMS5003 PM Sensor USD 15 - 20
Senseair S8 CO2 Sensor USD 25 - 30
SHT31 Temperature and Humidity Sensor Module USD 3 - 5
Button < USD 1
USB-C Connector 6 Pin < USD 1
JST Connector 1.25mm 8 Pin for PMS < USD 1
Resistors 5.1KΩ (2x) < USD 1
Resistors 10KΩ (1x) < USD 1
Female Pin Headers 4Pin < USD 1
Female Pin Headers 5Pin < USD 1
Screws PMS Sensor: M2*4.5 (Torx M6), PCB: M1.7x5 (Philips/Torx M6), Enclosure: M1.7x10 (Philips/Torx M6). The longest screws are for the enclosure. The screws with the washer are for the PCB and the remaining screws for the PMS Sensor.
USB-C Cable 90 degrees USD 3 - 6
SGP 41 TVOC/NOx Sensor (Optional) USD 15 (Available in the AirGradient Shop)
The schematics
The schematics
Firmware for PCB Version 3.7 including code for optional AirGradient SGP41 TVOC / NOx Module Your browser doesn't support this. Please use Chrome or Edge on Mac or PC. You are not allowed to use this on HTTP! Your browser doesn't support this. Please use Chrome or Edge on Mac or PC. You are not allowed to use this on HTTP!
Step Description
2 Once it is installed, go to File, Example, AirGradient and select the DIY_PRO_V3_7 code
Configuration
Configuration Number Temperature PM Unit Orientation
1 °C ug/m3 Top Left
2 °C US AQI Top Left
3 °F ug/m3 Top Left
4 °F US AQI Top Left
5 °C ug/m3 Bottom Right
6 °C US AQI Bottom Right
7 °F ug/m3 Bottom Right
8 °F US AQI Bottom Right
Photo of the Board with all the components placed
  1. Remove the black spacer with a small screwdriver or with a small pair of pliers (see Step 1 in the figure below)
  2. Take the hot soldering iron and push the pins inwards so that they do not stand out too much anymore (see Step 2)
  3. To ensure that the pins still have strong contact with the display, add some solder on the backside around the pins (see Step 3)
Steps to adjust the Display Pins
  1. Put the OLED display through the PCB and mount it into the enclosure. Make sure you tighten all four screws of the PCB. Move the OLED so that it is correctly aligned and use tape to temporarily fix it in place. Most of our enclosures have the display cutout on the bottom right. Make sure you solder the OLED display into the slot called OLED #1 (in case you have an older enclosure with the cutout on the top left, then use the slot called OLED #0).
  2. From the opposite side, check that the display is properly aligned.
  3. Solder the display as quickly as possible to prevent damage to the enclosure (melting or deformation from the soldering heat). Put the soldering iron at the lowest temperature that still ensures proper contact. After the soldering is done, immediately use a fan to cool down the solder points as fast as possible.
  4. Clip off the outstanding pins and carefully remove the tape without damaging the display cable.
Soldering the OLED Display onto the PCB
We use different kind of D1 Mini versions and the one we have made the best experience with is actually called "D1 Mimi" (with "m" instead of "n"). These boards are all compatible and interchangeable.
Pin Sockets on PCB
Pin Sockets on PCB
D1 Mini soldering
D1 Mini soldering
Then you can put the D1 Mini onto the PCB. Make sure that the orientation is correct and that all pins go into the socket. Ensure that the USB port of the D1 faces inwards and the antenna outwards.
SHT placement with pin sockets
Then put the SHT31 module onto the pin socket and make sure you have it match the form printed on the PCB. This means that the pins should align the following:
SHT PCB Label SHT Module Label
3v3 VIN
GND GND
SCL SCL
SDA SDA
Important: Compared to the smaller DIY Basic kit (Version <3.0), the pins here are soldered the opposite way to enhance the accuracy and airflow around the sensor.
Female pin headers soldering for the Senseair S8
PMS JST Connector
PMS JST Connector
PMS Cable Wiring
PMS Cable Wiring
PMS PCB Connection
PMS PCB Connection
After you have soldered the cable onto the PCB, connect the PMS5003 with the other end of the cable.
Then screw the PMS5003 onto the PCB. The PMS modules fan should face the edge of the enclosure so that it can draw in air easily from the outside.
You have two different types of screws in the kit. Use the smaller screws for the PMS sensor and also for screwing the PCB into the enclosure. The larger screws are for closing the two enclosure parts.
USB-C Connector
USB C Connector and Resistors
Button
It is important that you solder the button so that you can use our software and are able to switch different configurations (e.g. Fahrenheit, Celcius etc.). A 10k resistors is also required so that the button works.
Button and Resistor
Button and Resistor
If you purchased the AirGradient TVOC / NOx module, you can solder female pin headers onto one of the top I2C slots and plug the module in there.
Slot for AirGradient TVOC / NOx Module
Please make sure you mount the module in the correct orientation. The sensor needs to face outwards.
Please note that if you want to use some 3rd party TVOC modules, you might need to remove the pull-up resistors as the I2C bus already has the SHT and OLED module which both already have pull ups. We strongly recommend you use the AirGradient module which does not have pull-up resistors.
Screws for PCB
Screws for PCB
Location for PCB screws
Screws for enclosure
Location for enclosure screws
3D Enclosure
Download Enclosure STL Files
3D printable PRO enclosure
