User Settings AirGradient Dashboard
The menu is available on the side menu or can be directly accessed via: https://app.airgradient.com/settings/user
Alarms
Each user can subscribe to standard alarms set by the administrator of the organisation. You can also select if you want to be notified if an alarm has ceased.
If you need specific alarms not available in the list, please contact your administrator.
Change Password
If you have your own AirGradient password and do not use the Google login, you can change your password here.
PWA Update
If you have installed the AirGradient dashboard on your homescreen of your mobile device, sometimes new updates will not be immediately available. Here you can force the latest version to be used.
