The AirGradient Open Air Outdoor Air Quality Monitor (O-1PST Kit, PCB Version 1.3)
These build instructions are for the AirGradient Open Air Outdoor monitor model O-1PST. If you have a different version, e.g. the O-1PP model, please find your correct build instructions in this overview.
(The build instructions of the version that require soldering can be found [here](../diy-pro-v42/).)
The AirGradient Open Air Outdoor Monitor measures PM2.5, CO2, TVOC, NOx, temperature and humidity. These measures can be sent to a server (e.g. the AirGradient dashboard and map or any other cloud backend) for data logging. The monitor is fully open-hardware / open-source. Schematics, Ki-Cad files, enclosure step files etc. are all freely available.
outdoor parts mm4f6w8w a0se3il3
You can purchase the kit with all components from our Online Store which includes the plastic injected enclosure that looks really nice. We ship world-wide.
v42 assembled mm4f6wf6 0nj6am65
Skill Description
Computer A Linux, Mac, or Windows computer with the Arduino IDE installed to flash the software onto the microcontroller. You can also flash the software directly from the browser (recommended).
Screwdriver You need a torx (T6) screwdriver which is included in the kit.
Component Details
AirGradient Open Air PCB with ESP-32-C3
Plantower PMS5003T PM Sensor
SenseAir S8 module NDIR CO2 Sensor
SGP41 module TVOC/NOx Sensor
2x JST 8 cross-over cable for connecting PM and CO2 sensors
USB-C cable 4 meter long (for flashing and power)
2x Small Screws for SenseAir S8 module M1.8x11 (Torx T6)
4x Screws for enclosure M1.8x11 (Torx T6)
Screwdriver Torx T6
Assembly
The assembly of the unit is simple as no soldering is required.
Picture of fully assembled units before enclosure is closed
Connect the SGP41 sensor module
Plug in the SGP41 TVOC/NOx module into the pin holder. Ensure that the module faces outwards.
Please note that there is a small gap between the socket and the module. This is totally fine and does not impact the performance of the sensor.
Connecting the SGP41 module
Connect the S8 sensor module
Put the plastic washers onto the two bolts as indicated on the picture.
s8 connection washer mm4f6wul 6vrc7nr5
Screw in the S8 module using the 2 smaller screws supplied and connect the cable. Use the longer cable of the two supplied with the kit.
Connect the PM Cables
Connect the PM cable to the PM sensor. Make sure you put the cable into the PM sensor in the right way.
Connecting the pm sensor to the PCB
Placement of the parts inside the enclosure
Now you need to connect the two cables to the board. Connect the longer cable from the CO2 module to the connector labelled "PM2" and the shorter cable from the PM Sensor to the connector labelled "PM1". Then feed the cables through the feeder holes on the side of the PCB and put the board and PM sensor into the bottom part of the enclosure:
Closing the enclosure
After you have made sure that the cables are aligned correctly, the PCB is 100% upright and that all parts are fitted in correctly, carefully slide the top part onto the assembly. As soon as you feel there is some resistance from components or cables inside the enclosure, do not force it but lift up the top part and check again if the PCB is upright and the cables not interfere with the plastic rifts.
Once the two parts slide together smoothly, turn the complete assembly around and use the four longer screws to put it together.
The power supply is not included in the kit. Please get a standard 5v, 2A power supply. If you use the power supply outdoors, please make sure it is suitable for outdoor use and does not pose a safety risk.
Firmware Flashing Through The Browser
The device comes with pre-installed firmware so it’s ready to run, however, if you want to perform manual firmware updates you do so using this page: AirGradient Firmware Versions
Logging Instructions
  1. Plug in the USB C cable
  2. Press the blue button above
  3. Select the serial port your monitor is connected to. It is typically called “USB JTAG / Serial Debug”
  4. Click on “Logs & Console”
  5. Click on “Reset Device” to reboot the monitor
  6. Now you can see the debug messages and also identify the serial number.
BOOT Error During Flashing
In case you get an error called "Failed to initialize. Try resetting your device or holding the BOOT button while clicking INSTALL" during the flashing, you need to put the board into a special boot mode. To do this please follow below steps:
  1. Push the button labelled on the PCB and keep it pushed. This is also the button behind the small hole next to the USB connector at the bottom of the enclosure. So if you don't want to open the enclosure you can also press it with a small pin through the enclosure.
  2. Plug in the USB C cable
  3. Release the button. If you do not do this, the board will not get into the flash mode.
  4. Press the blue button above to flash
  5. Select the serial port your monitor is connected to. It is typically called “USB JTAG / Serial Debug”
  6. Follow the instructions for flashing. In case you want to delete previously saved WiFi passwords on the device, check the box 'Erase the Device'.
  7. After the flashing is complete, restart the monitor by unplugging the USB C cable (and plugging it back in)
AirGradient Dashboard & Map
The easiest way to start using AirGradient Dashboard and Map with your monitor is our onboarding wizard:
Dashboard Onboarding Wizard
When the monitor is connected and "Share data with the AirGradient API, AirGradient Map and 3rd parties" is activated, your monitor will appear on the AirGradient Map.
If you have some problems, please check out our knowledge base articles.
Connecting to WiFi
If you only want to connect your monitor to WiFi without using AirGradient Dashboard, please follow the WiFi Connection instructions.
Flashing With The Arduino Software
If you want to make changes to the code, you can do so with the Arduino software by following below steps.
a) Install the latest version of the_ Arduino Software on your computer.
b) Enable the ESP32 C3 board. You need to enable the MCU in the Arduino IDE by following these steps:
Once you have the Arduino Software setup for the C3 Mini, you can flash it with the AirGradient firmware.
Step Description
1 Go to Tools, Manage Libraries, and then search for AirGradient and install the AirGradient library. Make sure you install the Arduino AirGradient library version 2.4.3 or higher.
2 Once it is installed, go to File, Example, AirGradient and select the OneOpenAir.ino code
3 Read the instructions on top of the example code
4 Then edit/flash this code
Mounting
For accurate readings and optimal performance of your AirGradient Open Air Outdoor monitor, it is crucial to mount the device correctly.
Please follow the detailed mounting instructions to ensure your monitor is securely installed and functioning properly.
